Pier Foundation and Using Slate Tiles
neil_sykes987
by neil_sykes987 » Mon Apr 29, 2019 7:10 pm
hi, I'm having a home extension made and the builders have used slate tiles ontop of the foundation blocks as a base.
Is this a normal practice or should the foundation blocks be the same span as the bricks ontop.
I've kindly attached some images of one of the pier foundations
https://www.dropbox.com/sh/p0amz3ly571i ... STCca?dl=0
kind regards
neil
Hugh Schkok
Re: Pier Foundation and Using Slate Tiles
by Hugh Schkok » Mon Apr 29, 2019 10:50 pm
What you have here my friend is an old form of DPC. It's mot used im construction today instead they use a manufactured dpc. Maily because it breaks down from soil acids and stuff like that. Look closely to see if indeed there is a Ruberoid dpc on top of it. The bricklayer looks like a tgood one but his grand dad has forgot to mention that its 2019
I'll doubt that it is an acceptable workaround by building control but without knowing the exclusive direction of the column(s) it's hard to make a clear evaluation and I could be wrong I have been wrong in the past or so my little pit viper tells me but she lies a 'best before' date on food sold in Lidls.
neil_sykes987
by neil_sykes987 » Tue Apr 30, 2019 3:27 pm
hi, thanks for the info, had a closer look and there is a dpc membrain on the upper bricks, thanks for letting me know, really amazing contributor
Hugh Schkok
by Hugh Schkok » Tue Apr 30, 2019 5:09 pm
The p[pleasure was all mine. Happy to help and I hope we can do it again
Hugh
It is currently Tue Apr 29, 2025 9:46 pm
