Problem with Washing Machine Waste
7 posts   •   Page 1 of 1
max101
by max101 » Tue May 25, 2010 7:59 pm
Since we moved into our newish house we have a problem with the washing machine waste slightly overflowing the standpipe.
The waste comes out of the back of the machine then loops up and over (with a U shaped holder) and into a standpipe (approx. 1m high, 50mm diameter). There doesn't appear to be any kind of a blockage and it only leaks a small amount of water each time (but enough to be messy/annoying).
Do you think the w/m could be pumping the water out too fast for the drain?
Would it help if we changed the standpipe to a bigger diameter?
Any ideas would be most gratefully received! :)
Thanks for your help,
Max
plumbbob
by plumbbob » Wed May 26, 2010 2:09 pm
The standpipe should cope with the output of the washing machine so as it isn't it would suggest something is wrong. The pipe diameter should be 40mm (1.5") and a larger size is not available.
You don't describe the layout so it is a bit difficult to offer advice, but the overflow is most likely caused by a blockage, insufficient fall, too long a run or uneven pipe levels.
by htg engineer » Wed May 26, 2010 7:12 pm
How tall is the standpipe in relation to the washing machine ?
try extending the pipe.
htg
plumbbob
by plumbbob » Wed May 26, 2010 8:04 pm
htg engineer wrote:How tall is the standpipe in relation to the washing machine ?
htg
That's a point, can you hear the standpipe filling up or is it just splashing over?
max101
by max101 » Wed May 26, 2010 8:34 pm
The standpipe is approx. 700mm from the floor to the top.
The washing machine waste has to come through the wall and into a cupboard adjacent. It looks like the standpipe connects directly into the Svp through a floor socket ( hopefully if i have pasted this correctly you will se a photo!!).
Max
max101
by max101 » Thu May 27, 2010 5:32 pm
It's just splashing over. It never does it whilst I'm watching so I think its just occasionally during the wash cycle.
TheDoctor4
Help from DIY Doctor!
by TheDoctor4 » Thu Jul 22, 2010 9:46 pm
If you would like to find a reliable, insured and vetted tradesman in your area why not click through to the Find a Tradesman area of DIY Doctor: https://www.diydoctor.org.uk/find_tradesmen/ , complete the form and receive up to 5 FREE quotes
It is currently Fri Dec 20, 2024 9:19 pm
