In order to decorate, I have been able to remove and replace all the radiators in the house, with the exception of the hall radiator. All the other rooms have radiators with individual thermostats on them, the hall does not. I turned it off at the valves, undid the nuts, but it just will not come away from the pipes either side. I also tried tightening one nut back up and trying to just remove one end, it still wouldn't budge.
I didn't want to try and force it in case i damaged the pipe work.
Can anyone suggest anything - hopefully this isn't too daft a question!
Thank you!
