Towel rad fittings
carruthers
Towel rad fittings
by carruthers » Sat Feb 07, 2009 12:47 pm
Help ,please
I am replacing a 500 x 700 rad with a towel rail the same size, but the fittings for the towel rail are at the back and are at 460mm whilst the existing rad is at 500mm. How do I make the connection. The supply is on 9 or 10mm copper and come out through the skirting about 18mm off the floor.
Any advice would be much appreciated.
Regards
Carruthers
Steve the gas
by Steve the gas » Sun Feb 08, 2009 7:44 am
You prolly need the pipework altering and use angled rad valves.
Hth
carruthers
Towel rad fittings
by carruthers » Fri Feb 13, 2009 4:05 pm
Thanks to Mike the gas, had thought that might be the case.
Carruthers
It is currently Fri Nov 22, 2024 11:51 pm
