FLOOR JOIST
BOILER
FLOOR JOIST
by BOILER » Sun Oct 31, 2010 10:36 pm
I have to drill a new vertical hole through a floor joist to accommodate a 15mm central heating pipe. The new hole is very close to an existing one and therefore would significantly reduce the joists strength in this region. Is there a metal strap commercially available to strengthen this region or can anyone suggest a solution?
Many Thanks.
BOILER
Re: FLOOR JOIST
by BOILER » Tue Nov 02, 2010 12:11 pm
BOILER wrote:I have to drill a new vertical hole through a floor joist to accommodate a 15mm central heating pipe. The new hole is very close to an existing one and therefore would significantly reduce the joists strength in this region. Is there a metal strap commercially available to strengthen this region or can anyone suggest a solution?
Many Thanks.
I should have added that the joist is at the perimeter edge of a ground floor room, it almost touches the wall on one side, and the pipe is for a new radiator. Rubble is 600mm/24" below the flooring.
Thanks.
It is currently Mon Dec 23, 2024 7:55 pm
