Paint on entrance gates has run
seaspray99
by seaspray99 » Sun Apr 10, 2011 6:55 pm
Hi I primed two entrance gates and used Dulux Once which is an undercoat and top coat combined paint, I appreciate its rubbish, I was in a rush to try and finish the gates, anyway the paint was put on thick and its run and gone streaky and has the Orange peel effect, its a bad job, its been on 4 days and is still soft.
The question is what is the quickest way to remedy the situation ?
Many thanks for your time !
chris_on_tour2002
by chris_on_tour2002 » Mon Apr 11, 2011 12:59 pm
solvent based paints will remain soft for several weeks after application.
i suggest you leave it a few weeks, give it a good sand and then repaint with an undercoat and separate top coat.
JRS
by JRS » Mon Apr 11, 2011 6:01 pm
Dulux once is just a name to com people in my opinion, Get a proper undercoat and gloss. But would leave it a few days sand it down and recoat properly
chris_on_tour2002
by chris_on_tour2002 » Tue Apr 12, 2011 10:09 am
As a DIY product Dulux Once is fine if used correctly on prepainted surfaces where the existing paint is sound and only requires a light sanding.
It is not really the stuff to use for this application. Furthermore gloss paint will always run and streak if applied too thick.
It is currently Fri Jan 10, 2025 6:01 pm
