power shower wiring setup
8 posts   •   Page 1 of 1
wolfytom
by wolfytom » Tue Jul 03, 2007 12:04 am
I'm installing a mira thermostatic power shower. This needs a supply only for the internal pump. It does not heat water.
I have fitted a FCU with built in RCD, in the airing cupboard, taking its supply from the socket circuit. I have used 1mm twin core and earth.
From the FCU the cable goes to a 40 amp pull switch with neon indicator and from there to the shower.
The main consumer unit has a built in rccd for the socket circuit.
The instruction manual states that...
[b][i]230–240 V, 50 Hz, fused at 3 Amps, via a double
pole switched fused connection unit (not supplied) with a minimum 3mm
contact separation in each pole.
A 30 mA residual current device (RCD) must be fitted. This may be part of the consumer unit or a separate unit.[/i][/b]
Before I switch it on, can you tell me if my setup sounds about right???
Any advice is much appreciated - thanks in anticipation
Andy
BLAKEY1963
Re: power shower wiring setup
by BLAKEY1963 » Tue Jul 03, 2007 9:56 am
[quote="wolfytom"]I'm installing a mira thermostatic power shower. This needs a supply only for the internal pump. It does not heat water.
Andy[/quote]
WOLFYTOM.
MY ADVICE WOULD BE THAT WORK IN A BATHROOM
IS NOTIFIABLE UNDER PART P. FOR YOUR OWN PEACE OF
MIND AND SAFETY , GET A REGISTERED LECKIE TO
CHECK THIS FOR U. PLEASE.( TEST , INSPECT, CERTIFY )
BLAKEY1963
wolfytom
by wolfytom » Tue Jul 03, 2007 11:49 pm
I know about the need for a leckie - I just asked for a bit of advice.
If everyone answers like you have the forum will cease to exist. Can't you provide some practical advice and leave me to make the judgement call?
:roll:
BLAKEY1963
by BLAKEY1963 » Wed Jul 04, 2007 2:19 pm
[quote="wolfytom"]I know about the need for a leckie - I just asked for a bit of advice.
:roll:[/quote]
WOLFYTOM
THANK U FOR YOUR COMMENTS. PRACTICAL ADVICE
FOR NOTIFIABLE WORK IS BEST COMING FROM YOUR
REGISTERED ELECTICIAN ON YOUR JOB THEN U CAN MAKE
THE JUDGEMENT CALL AND BE REST ASSURED U HAVE
GOT THE CORRECT ADVICE AT THAT TIME .
I WISH U LUCK IN THE COMPLETION OF YOUR PROJECTS
BLAKEY1963
koicarpus
by koicarpus » Wed Jul 04, 2007 7:16 pm
You need to cross bond your new feed to the shower pump with everything else in the bathroom!
Apart from that it sounds ok.
by sparx » Wed Jul 04, 2007 9:16 pm
the forum is here to help those who want to do it right, & I presume you make 'judgement calls' abt lighting up in pub, doing 90 through the high street, parking on ped. crossings etc?
Blakey's telling it like it is, he (& I ) have to; if you know better why ask?
You could have saved not spent money if you had used leckie as he would not have fitted unneccessary RCD spur and expensive 40A pull sw. you didn't need!!!
Take heart Blakey, some want to learn, some are willing to learn & some........
SPARX
BLAKEY1963
by BLAKEY1963 » Wed Jul 04, 2007 9:44 pm
[quote="sparx"]the forum is here to help those who want to do it right, & I presume you make 'judgement calls' abt lighting up in pub, doing 90 through the high street, parking on ped. crossings etc?
SPARX[/quote]
SPARX.
I HAVE FOLLOWED THE TRAIL ON OUR FORUM AND FULLY
UNDERSTAND WHAT WOLFYTOM WAS TRYING TO UNDERTAKE,
AFTER READING HIS INPUT. I HOPE WOLFYTOM WAS NOT
OFFENDED BY MY ADVICE. PART P IS HERE TO STAY AND I
HOPE IF GUIDANCE FOLLOWED , IT PROTECTS THE PUBLIC
BY ELECTRICIANS FOLLOWING THIER INSTALLATION
GUIDELINES , AND PEOPLE LIKE WOLFYTOM CAN BENEFIT
FROM HAVING A SAFE INSTALLATION .
SPARX ONCE AGAIN I THANK U 4 YOUR INPUT BECAUSE
WE KNOW THE DANGERS THAT ELECTRCITY CAN CREATE
AND IF THE RIGHT ADVICE CAN BE GIVEN THEN WE MUST
DO THE RIGHT THING AND TELL IT HOW IT IS .
THANKS SPARX .
BLAKEY1963
wolfytom
by wolfytom » Wed Jul 04, 2007 10:36 pm
Jeez, I could have saved, not spent money, by buying in a lackie!
That was so funny I've just sprayed red wine through my nose and all over my lappy!
The RCD cost 20 quid and the pull switch 14 - even if I have bought 'em in error, I've saved myself about 500 quid! And my error is to err on the side of caution! Not a bad judgement call.
Sparx, you spend a lot of time on this site - get yourself a holiday, mate!
It is currently Sat Sep 28, 2024 11:35 pm
