Replace a raiator with towel rail on a Combi bolier system
glyn
by glyn » Mon Apr 14, 2008 8:39 pm
I have to change a radiator to a towel rail and the the problem is that the boiler is a Combi boiler - How do I remove the radiator?
rosebery
by rosebery » Tue Apr 15, 2008 1:14 am
Turn off the water at the mains stopcock.
Drain down the system.
Change the rad for the towel rail.
Repressurise the system.
PS Not a tiling question and you'll find this one has been answered relatively recently in the plumbing section.
chris_on_tour2002
by chris_on_tour2002 » Fri Apr 18, 2008 2:13 pm
rosebery - is it strictly necessary to shut of the water main? if the boiler has a filling loop there shouldn't be any immediate danger of accidental filling.
rosebery
by rosebery » Fri Apr 18, 2008 7:18 pm
Chris
How else do you completely take the pressure off the system? I grant you that it shouldn't be necessary except if you are working on the DHW but it's probably not a bad practice for someone who only does a bit of plumbing work now and again on a DIY basis.
It is currently Sun Dec 22, 2024 5:40 pm
